780xlt Alpha Tag help
flugpop
Alta Loma California
I'm trying to setup my 780 xlt and in group monitor I am getting and error of
HTTP/1.0 200 OK' not received . My 780 is communicating with Group monitor because its sending the ID's to it and it is corresponding with the ID's that I have setup. Can you tell me what I am doing wrong? Also in Oddcast do I have to tell it too look at a specific IP address for it to work? Thanks in advance
kd7ckq
No. AZ
I would get something like that when using ID Tracker. I would have to go into the configuration file and specify the IP address and com port of the host machine. If my machine went off and came back on. I would have to check the IP address to see if changed and if so make the appropriate change in the config file.
