794.559375MHz Ottawa
alfonzo1955
Ottawa, ON
Does anybody know what 794.559375 in Ottawa is? I was searching around for frequencies when I got it. I am near Carleton University.
DaveH
Ottawa, Ont.
What does it sound like, and when did you hear it? I'm not far from there myself,
not hearing anything at the moment.
Dave
alfonzo1955
Ottawa, ON
Every second or so, there is a little burst of white noise. Every now and then, there are people talking. I have a PSR-310.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
You're receiving an 'image' of an 800 MHz frequency. GRE radios receive false signals in the 794-799 MHz area of frequencies generally around 864-869 MHz.
Jay911
Image Frequencies - The RadioReference Wiki
There are quite a few threads about this issue.
http://forums.radioreference.com/te...6065-frequency-792-3625-around-nashville.html
http://forums.radioreference.com/massachusetts-radio-discussion-forum/234700-794-684375-a.html
http://forums.radioreference.com/illinois-radio-discussion-forum/232079-793-1875-a.html
http://forums.radioreference.com/sc...00-wont-accept-700mhz-channel-input-freq.html
http://forums.radioreference.com/wa...rum/230218-frequency-766-643750-question.html
The easiest way to figure out what frequency is actually in use is to listen to the ~866 MHz band simultaneously with another scanner and figure out what frequency you're hearing that way.
It's probably one of the Ottawa area trunk systems. Do you hear the telltale EDACS beeps at the end of transmissions?
alfonzo1955
Ottawa, ON
I don't believe I hear beeps after the transmission. If I do, does that mean it is possible to listen to a trunked system using a conventional scanner?
Forts
Ontario, Canada
I get images in the same area on my Pro-106 from the City of London's EDACS system. Was quite puzzled when I found an EDACS control channel in the 790's one day haha
VE3JSO
sarnia ont
i have seen that with the lambton edacs on my pro 106 as well i thought it was a new system at first
