Happy Thursday everyone!
There is an update for EZ Scan today for the TRX-1 &2 and WS1080/88 & WS1095/98
Changes to the TRX-1, TRX-2 PC app are as follows:
Changes to the WS1080/88 Handheld, and WS1095/98 Base-Mobile PC app are as follows:
Happy scanning!
Whistler Wendy
- Fixed an issue on the conventional screen where selecting an option to convert the alpha tags to all upper case would reset the delay for those channels to 0.
- Added a warning message when converting object alpha tags to upper case noting that it is not possible to return the alpha tags to their previous settings without editing each one individually.
- Fixed an issue where after completing a library import using the preferred method and then returning to the county or state screens, it was not possible to return to the location select screen without restarting the application.
- Fixed an issue where the search button was enabled on the conventional, talkgroup, and radio ID screens when no objects were present on those screens. Clicking on the conventional search button under this circumstance would cause a crash.
- Fixed a crash when right clicking in the conventional listing when no frequencies are present.
- Created a new Search Tab that includes options to configure all search types. All search options previously on other screens (i.e. Clear all lockouts, search record, etc.) have been moved to this area.
- This version of the PC App will recognize both the North American and Non-North American versions of the TRX-1 and TRX-2 scanner for firmware updates. Be advised that switching between these firmware versions will change the available bandplans and reset all global options to defaults.
- Updated help file to include information about the new search tab.
Happy scanning!
Whistler Wendy
