8.894
Intellifax
Just a few aircraft from 8894 KHz in about 15 minutes listening time:
EL AL 102 to Algiers Radio
Air France 805 to Algiers
Lufthansa Cargo 8277 to Nouakchott Radio (Mauritania)
Just position reports. Freq had lots of QRM from HF-ACARS in USA.
Listened for a bit on 8918 also, usual aircraft checking in with New York. Also heard N488RC (G-200 from Venezuela to Teterboro), G-SANL (BD-700 GLEX), and Shark 18 there.
Jimepage
Atlantic City, New Jersey
Hey Intellifax nice catches did you get the info from selcals? If so what software do you use? 9times out of 10 I get the ATC towers on hf but barely hear the airplanes clear enough for ids
Intellifax
All the info I got from the above was from the voice transmissions. Then I use several public databases to determine routing, type of aircraft, etc. I also check the selcal when it is given. Wish I had a selcal decoder, but haven't found a free one that actually works. Still looking for that.
With the sunspot cycle getting better and better, I've been checking out some freqs that I normally don't listen to, with some decent results. Can't wait until I put up a 600-700 foot longwire this spring. All I'm running now for HF is a crappy G5RV.
Intellifax: Im also looking for a selcal decoder but as you said nothing free and the only one i know of is from airnav. Sorry to hear you don't like your g5rv i have one also and so far so good.I was looking into loop antennas but they are to much money. I will let you know if i find anything online that is an open source selcal decoder.
Jimepage
multipsk has one you can use for 5 mins but I just restart the program for 5 more mins. Its not too detailed just throws the selcal code which atleast tells you what kind of plane it is.
I have been using multipsk for a long time and i never looked to see if it did selcal. Thanks Jim
