ShawnCowden
any update on anything on the new digital 800 mhz system coming on in kentucky ksp system ???
thanks,
shawn
thanks,
shawn
ShawnCowden said:any update on anything on the new digital 800 mhz system coming on in kentucky ksp system ???
thanks,
shawn
thanks,
shawn
KR4BD said:Yes, KSP is UHF (450-460 mHz) right now. But they have been granted a slew of 800 mHz frequencies statewide...
studgeman said:FYI the conventional UHF P25 System, already has multiple talkgroups on it.
N_Jay said:They "KSP", or They "State of Kentucky"?
P.S. (Minor thing) its is MHz, not mHz
KR4BD said:1--KSP=Kentucky State Police
2--It's mHz!! H is for the proper name Hertz. m is for mega
studgeman said:KSP has continuously been building a 800MHz MDT system based on IP Mobile net. The plan has been for several years now to extend it accross the state and allow the locals on it. Actually in some areas, mostly northern KY, this is already the case. FYI the conventional UHF P25 System, already has multiple talkgroups on it.
studgeman said:I believe they are all Commonwealth of Kentucky. It has been about 6 months since i really looked at the licenses.
With a Project 25 Conventional system you can create talkgroups on the system, it is similar to the old multi-PL repeaters, except, with P25, its much more advanced. One of the biggest advances is the ability to build a heirarcical structure of groups just like you would be able to in a normal trunked system, ie one talk-group can talk to multiple talk-groups. there are also some provisions for priority, and of course emergency access.
I think if you dig in the forum you will find some references to Motor Vehicle inspections operating on the KSP UHF system, but on a seperate talk-group.
studgeman said:That being said, to the scanner listener, you would never know the difference. The scanners built for P25 are not sensitive to such information, it just decodes all the fames marked as voice.
KE4ZNR said:I think we are getting the KSP UHF conventional radio system (which uses frequencies not talkgroups) mixed up with a trunked system that uses talkgroups...KVE (Kentucky Vehicle Enforcement) uses the Frequency of 453.300Mhz in Digital conventional format not in a "Talkgroup" format....once again KSP is using a CONVENTIONAL (not trunked) UHF Digital Multicast System using frequencies (not talkgroups)...
