800 MHz Mobile Antenna Length?
KT4HX
Spotsylvania County, Va
Been reading some various sites about antenna length/gain. Wondering what others have experienced on 800 MHz using 1/4 wave, 1/2 wave, 5/8 wave or a full wavelength mobile antenna. At what point will optimal gain occur with no impedance issues? Thanks!
DaveH
Ottawa, Ont.
Interesting question. There are a lot of different designs, from the 1/4-wave
(unity gain) up to stacked 2-element ones (with the phasing coil between them).
Gain ranges from 0dB for 3" whip to about 5dB for 5/8-over-5/8.
There is no practical 1-wavelength antenna by itself, but there are 1/2-wave
over 1/2-wave designs. The "optimal" impedence is 50 ohms, and impedence
matching is done at the base for all designs if needed (the 1/4-wave doesn't).
There is always a trade-off between higher gain and narrower bandwidth,
plus extra cost; you don't get "something for nothing". Really high gain has
another disadvantage. The vertical angle over which this gain occurs gets
progressively smaller. In some cases you can end up with lower gain than
for a simpler antenna, such as going up and down hills etc.
The ones I use are typically older cellular antennas (mag mounts) with
3dB gain, in one case a 5/8-5/8 with 5dB. They all seem to work OK.
Avoid ones pre-wired with "spaghetti" coax due to high loss.
Dave
N
N_Jay
Guest
About the best mobile antenna going (but it is ugly) is the elevated feed 3dB gain commercial antannas. I think they are 1/2 or 5/8 wave by design, but that is not important to the user. They are isolated from teh vehicle and have their own ground. The height also helps.
KT4HX
Thanks Dave. Well I can get a magmount whip with no problem (RG-58U) and was thinking of trimming it down for 800. Was considering going with either 1/2 wave or 5/8. Just wanting to get some feedback before I did anything. Appreciate the response. :D
JohnWayne
Lynchburg, VA
Your best bet is the good old 3dB "cellular" style antennas. They work very well and are inexpensive. You can get higher gain antennas, but the price goes up very quickly; expecially so for an elevated feed style. I sell an Antenex QW8063 in chrome and the Antenex QWB8063 in black. I also have a just about any type of mobile mount that you could want.
Let me know if you have any questions.
Thanks,
Jeff
