800 mhz question
fd71022004
Anyone know the plus(s) and/or minus(s) between open coil
and closed coil antenna whips? Thanks, John
N4JNW
Irvine, KY
A coil is a coil, whether it's covered or not.
A closed coil, usually has a smaller diameter wire inside , for the coil, instead of the same diameter wire in an open coil style. Because of this, open coil antennae can usually handle more power.
Some closed coil antennae have a liquid oil inside the load, which the coil is submerged in. This helps with heat dissipation during transmit.
Of course, if you're scanning, and recieving only, I don't really see why it would matter..
