800 Mhz ReBanding In Canada
FoeHammer
Windsor Ontario
Does anyone know If & when 800MHZ rebanding will occur in Canada
any shedules or info ? specifically im in Windsor Ontario bordering with detroit & I think they are working on it over there now So when my 396 comes in I imagine there will be a point ill have to flash it for the reband to continue hearing detroit , idunno if that would screw up listing to windsor until it catches up or what ,....sigh I miss the simple one frequeny per crystal days of scanning,....
seamusg
Grand Blanc, MI
I don't remember the web site, but when I looked up Warren,Mi, it said pending treaty with Canada, so I'm not sure how it will effect Windsor.
Now 1000 per scanner.
Forts
Ontario, Canada
I had a reply from UPMan regarding the whole rebanding issue a while ago (for those who don't know, he is a memeber of this site and is a Uniden product manager). He says once rebanding is under way, and current radios are reflashed to properly follow those systems, 'non-rebanded' system will still trunk properly using the new firmware. So if you upgrade your radio to listen to Detroit, you don't need to worry about messing up your Windsor stuff.
