I had the 800 working fine.
I went and imported a city that went to P25. Upon doing so I updated others cities too. Now none of the cities I had previously working receive traffic as they used to.
Is there a way to reset or delete all memories and start fresh ?
Unfortunately I did not save my previous config in an archive or I would just reload it.
The best way I see to load a city or area is go to the import tab and select the city, then which department you want PD or tac ect. Is this how you guys do it ?
How do you folks program yours ?
I've gone through the manual several times and have successfully programmed and had this working fine in the past.
Suggestions ??
Suggestions ??
