I get the impression you might be out-of-luck with the Pro 95, unfortunately.
From what I've read, the three conditions for whether a scanner will be able to handle the rebanding are:
- The scanner will come from the manufacturer will firmware written to follow the new / rebanded frequency architecture
- The firmware can be upgraded by the owner, via a file from the manufacturer, to follow the new architecture
- or -
- The scanner can be manually programmed for custom look-up trunking tables
Nothing on the horizon matches the first condition. Even the widely-heralded Uniden 396 MAY be shipped with the current frequency architecture, requiring a firmware reprogramming.
Only a couple of the most-recent Uniden scanners meet condition two. The Uniden 250 / 785 and 780 - and earlier scanners - WILL NOT be upgradable.
I believe only the Pro 96 / 2096 meet condition three, and have enough custom tables to handle the expected changes to 800 MHz under rebanding.
Rebanding will be an interesting period for our hobby ... kind of like a bear stock market. Alot of scanners will drop in their value as trunktrackers "overnight." But there will also be some good values on the used market for scanners, if you have some non-trunking use in mind.
And, be careful about buying a used two-way trunked radio, if you don't understand how that radio will be affected by the rebanding.
Jeff Multer
