800 trunk
coolrich55
connecticut
How come on a system I try to monitor, I can't because apparently I'm out of range for the CC's but I can pick up the VC's just fine? Is that normal for some systems?
a417
are you sure it's a range issue for your inability to monitor? What systems in the state are you trying to pick up?
R
retiredmich
Guest
Do you have the CC's turned on ? What type of scanner do you have ?
kennyloatman
Cumberland Co., NJ
Do your CC's rotate? Mine change about once every 24 hours. Some come in strong while others are weak. Same with the voice channels. Depend which VC is picked as to how clear it comes in. I am only 3.5 miles from the tower.
coolrich55
connecticut
I have a psr500. I'm trying to monitor the Massachusetts state police system, Boston site. When I hit analyze and go through the frequencies I get nothing from the CC's but hear audio over the VC's. All the other sites I monitor work fine. I asked this question on the Mass forum and someone told me I'm out of range of the control channel. I just found it odd that I can pick up transmissions on the voice channels.
ecps92
Taxachusetts
Which Boston Site (Freq and Zone Pls) as there are
Zone 1, Zone 5, the 700 Overlay and a few others
Also, From WHERE are you trying to listen to it ? As your Profile says CT
coolrich55
connecticut
When I'm in Rhode Island I'm able to listen to them. Zone 5 I can receive no problem. It's zone 1 I'm having issues with. The BFD is what I like listening to and for the past few years I have been able to on the simulcast or patch on zone 1. 49200 is the ID. But this past year from the same location, Cranston on a hill, I get nothing from the CC's anymore. In the past it wasn't the best signal but was around 60-70% which was enough. Like I said when I scroll through the VC's I'm hearing BFD transmissions and even shows me the ID.
ecps92
Taxachusetts
Well First Zone 1 is designed to cover Metro Boston (think roughly inside of Rte-128 Only)
so, don't expect to even hear it South of Norwood MA
Zone 5 is more wide area and is handled by 9+ Sites, if you are in RI you are hearing (Most likely) Wrentham
Your better off using a UHF Beam (470-512) and trying Boston Fire on the 483 Mhz channels
coolrich55
connecticut
I have no option for a different antenna. Just using a RS 800mhz. What I did yesterday when I was in RI, I programmed in the voice channels in conventional mode and scanned them. I was actually able to monitor the 4 alarm fire in Boston by doing this. It's not ideal but better than nothing. And it's definitely zone 1 that I was picking up. Like I said, voice channels come in fine, nothing from the control channels.
buddrousa
Are you importing from RR or are you putting in the data by hand?
You have to import sites and talk groups both to hear trunking systems.
If you can hear the Voice Channels there is no reason you should not hear the Control Channels.
ecps92
Taxachusetts
As said, Zone 1 was designed for Metro Boston, consider yourself lucky to even get the Voice channels that far away from a Zone 1 tower site
And even Zone 1 users have issues with coverage, which is why they have begun implementing the 700 Mhz overlay
