APX 8000 beeps during transmission
sun732
I was delegated the duty to fix the beeping heard during reception but don't know on our new APX 8000what to look for. not trunked, not secured and non astro.
I have very surface level knowledge, read the documention and have access to the motorola programming software.
All our APX 8000 beeps during reception. Reception isn't the greatest either but that is normal. Our Xts 2500 don't do it.
Thanks for the help!
TJX400
Central Virginia
Does the tone sound like the keypad tone, or something of a bit lower frequency? There are two different options I'm thinking of.
GTR8000
NY/NJ Database Guy
BEE00
Does the beep go away when you take the radio out of scan? If yes, then disable the Priority Scan Alert in Scan Wide.
sun732
It sounds like a higher pitch tone. I disabled clear alert tone and seemed to have fixed it but unsure.
sun732
That, and then check if clear alert tone is on for RX only.
I just had the one radio and transmissions slowed down quite a bit as it was near end of day so I wasn’t able to really confirm but haven’t heard the beep since.
Just to confirm my understanding, the clear alert tone for RX will beep at intervals during reception to tell me comms I’m hearing are unsecured? Furthermore, would moving the switch (the one with the circle under channel selector) from secure to unsecure achieve the same result I’m looking for?
I really appreciate your help by the way.
K2NEC
It will beep at the start of the transmission to tell you it's not secured, and no, the transmission you are receiving is still unsecure so switching your radio to secure won't fix that.
TJX400
Central Virginia
The clear alert tone option can be found in the secure options. The scan alert tone can be found in both radio wide and scan options.
sun732
Thank for the help! Issue has been fixed
