altec
I was reading this link http://www.radioreference.com/forums/antenna-forum/135913-800-mhz-portable-scanners.html and have a couple of questions on how to amplify the control channel.
Outside the house with my portable 396 I can barely get the control channel to come in using rs 800MHz antenna. It has quite a bit of static but barely readable standing still. The signal is about 50 miles away. I want to amplify the signal. Would this work if I built a 800MHz yagi antenna? If it does improve the signal pointed in the right direction about how many elements would be ideal?
Also sort of a stupid question but after I placed all the elements on the boom without the driven element and put the portable scanner using the 800 RS antenna next to where the driven element at standing level, would I get improved reception trying this? Thats without the driven element and balun standing at ground level pointed in the towers direction. Like I said you can monitor the system standing outside almost but could this improve reception without having to erect a tower for the squirrels to play on?
All in all just picture it as this, "I like sitting in a chair outside in the lawn sipping on tea and enjoying the sun. If I had a yagi mounted to the yard table with my scanner next to it would I get improved reception? Thanks, Altec.
