A 75 metre antenna?.... I love it!
Anyone familiar with my posts knows I am a great fan of ground mounted verticals.
They can be constructed simply, they are very efficient, and don't take up much space. The following is an example of one I use at home, with some of its pro's and con's.
Its a ground mount, on a 3" diameter iron pipe ~6 feet deep. The insulator is a section of industrial plastic pipe separating it from the radiator, which begins about 18" above ground. There are about 20 radials streaming off the base, buried an inch or two- varying between 12 to 18 feet in length-- the radiator is about 20 feet high, an un-guyed 2" irrigation pipe couple thru an Icom marine band auto tuner, which gives me an in-station SWR of better than 1.2:1 across 1.8 to 30 Mhz's (the efficiency, of course, will vary across said frequencies for obvious reasons.... but its got a great SWR.)
How good does it work?? Well, I don't chase DX, but with an Alaskan callsign I am often mistaken for being in Alaska - I get called by some rare DX often*. With this antenna I can talk to virtually anyone I can hear with 100 watts. I have another, similar antenna for 160-- a longer radiator, longer radials-- and a heftier manual tuner (kilowatt)- manually set to one frequency---- on this band I don't often QSY-- this, I use on 160 (though not very often anymore.... )
The Pro's? -- these antenna's have low angles of vertical(!) radiation. This is especially important on 160 and 80/75. At the height's ham string wire antennas, most of the radiation angles will be very high-- as in NVIS-- on these two bands. On 160 these wires might as well be called Dummy Loads.
Okay, I can hear the grumblings ....
...... but Hey Guys!... this is my experience- ham and professionally.
Another plus?... these things are sturdy. They don't blow down, they don't get taken down easily by trees,... they don't have coax dangling from centre fed insulators to ensare the innocent ,... you don't have to cut-and-try ...endlessly... them into resonance like a dipole...., ground mounted they offer some degree of better lightning/static protection,... they have a small 'foot print,'.... did I mention their low angle of +vertical+ radiation?..so essential on 75/80 and 160??...Oh, good,-- I did.
The Negatives? Did I mention the low angle of radiation?.. well, not a good thing if you are surrounded by anything looming over 6 or degrees in the near field (as in: Mountains.) But in the 1.5 to 4 Mhz, the vertical ground wave and higher incidence of incoming sky wave make this less important than if it were 10-30Mhz.
Want something simple to try?... get a Hustler mobile 75 meter resonator; then by cleverness, adapt it to the end of a 12 foot aluminum 'painter's pole" from Home Depot. Make an insulated base,... string out the best array of counterpoise you can get away with... feed it with coax (72 Ohm's will do- 50 is even better)... on low power resonate the coil-- you will have to shorten that upper whip above that coil...... and see how great That works on 75.... and then tell me about it....
Regardless of what you decide on, have fun with it all, N4AOF... !
........................................................CF
____________________________________________________
maybe its also the female voice?? or so I have been told....
