850 Yagi Build
cb360t
Inspired by Airdorn's post (http://www.radioreference.com/forums/showthread.php?p=885282#post885282), I thought I might give this a try.
Because I live in a fringe area in a valley, the only way I am able to use my 800 MHz GSM cell phone (LG CU500) in my home is to hook it up to a Wilson amplifier (http://wilsonelectronics.com/ViewProduct.php?ID=123). The amp is currently fed from a Wilson mobile antenna (http://www.wilsonelectronics.com////ViewProductB.php?ID=5) placed in a high window facing north in the general direction of the cell tower. This combination usually provides my phone with two bars of signal. This equates to a RSSI reading of -96 in test mode.
In a quest for another bar or two of signal, I’ve considered replacing the mobile antenna with this Wilson Yagi: http://www.wilsonelectronics.com/////ViewProductB.php?ID=14. Thirteen dBi would seem to trump 5.12 dBi. Since this Yagi appears to be relatively simple, I thought I would look into the possibilty of home-brewing my own.
To this end, I used Meserve’s Quick Design web site (http://www.k7mem.150m.com/Electronic_Notebook/antennas/yagi_vhf_quick.html) to work up the specs for an 850 MHz eleven element Yagi. I also used Meserve’s Feed Design site (http://www.k7mem.150m.com/Electronic_Notebook/antennas/yagi_vhf_feed.html) to get a handle on a folded dipole feed. For the basic nuts and bolts of construction, I thought I would follow Airdorn’s lead at http://www.radioreference.com/forums/attachment.php?attachmentid=15680&d=1211762991, I planned on using 3/16” (.1875) brass rod for the elements and ¾” aluminum channel for the boom. In the interest of a shorter boom length, I’d like to limit it to six elements by eliminating D5 through D9.
Here is the design so far.
Spacing Element Length
Zero REFL 7-15/64"
2-25/32" D.E. 6-9/16"
3-13/16" D1 6-23/64"
6-5/16" D2 6-9/32"
9-19/64" D3 6-3/16"
12-25/32" D4 6-7/64"
16-21/32" D5 6-1/32"
20-53/64" D6 5-31/32"
25-13/64" D7 5-59/64"
29-25/32" D8 5-7/8"
34-37/64" D9 5-53/64"
I would appreciate any comments, tips, gotchas, etc. before I dive in. Feel free to pass on anything I may have overlooked. Thanks for reading.
K4NRG
You should check the specs on the model phone you have. http://reviews.cnet.com/cell-phones/lg-cu500-at-t/4507-6454_7-31987406.html?tag=mncol;rnav
Since it is a multi mode, dual band phone, the yagi you will need will need to be dual band as well: 800MHz and 1900MHz. Check this link - https://www.maximumsignal.net/store/product.php?productid=16208&cat=5&bestseller=Y
I have used this antenna and similar booster combinations in applications just like you're describing with good results. The trick will be finding the site closest to you for the direction to point the antenna.
As I understand it, the lower frequencies are generally used for SMS and narrow band applications while the higher frequencies are for wideband data and voice apps
