8CALL90 poor signal, but can't seem to squelch it
mk262
Flagler County
Hi! I have a pro-197 with an attic mounted ST2 (rg6, not rg8).
I recently started scanning the national interop frequencies. Almost immediately when I scan the 800mhz ones, I start picking up 8CALL90 (851.012500 NFM with dpl of 156.7) and it's very static-y. Even if I attenuate the object, there's basically no change. It also doesn't matter if I turn the squelch all the way up, I continue to pick it up.
What's interesting is that I have my squelch mode set to search. So the fact it's picking up the dpl of 156.7 would seem to indicate it's actually receiving a real signal, not interference--but maybe I'm wrong.
I'm a little frustrated because I don't know how to fix this. Here's a link to what the audio sounds like.
Thanks for any help.
N8IAA
Fortunately, GA
Your link opened, but there was no audio. My guess is that because it is a simplex frequency, unless they are close, you won't hear them. I am getting some intermittent signals on my scanner with squelch being broken and very low voice signal. It's used here in GA for interops a lot in the Metro ATL area. Maybe try a gain antenna.
HTH,
Larry
mk262
Flagler County
Correct, there's basically no sound at all. That's what I didn't understand. If it's attenuated and the squelch is at maximum, shouldn't I be hearing something, even if it's not clear?
DickH
I can hear some sort of data, but it's very weak. I doesn't sound like control channel or MDT.
