900 mhz XTL1500
mass-man
trying to retire...
Parker Co., TX
Is this radio programmed with the Astro P25 CPS as the digital versions are?
Is extensive hex editing necessary to program in the amateur 902/927 band?
Time to move away from the MCS2000 series and the XTL1500 shows up at times at a reasonable price.
thanks....
KG4INW
Midlothian, VA
It's the same CPS but does appear to require hex editing. Hopefully this helps (although the info is for CPS 11 there should be ways to make it work with any level): Motorola XTL Information
