940.22 MHz - What is it????
justinbucherj
Washington DC
I came across this signal at 940.22 MHz and it caught my attention because it was so strong. And it had this same strong signal strength around an area the size of a small town. Driving in approximately an 8.5 mile circle there is almost no change in signal strength. As soon as I go outside that circle it drops off. I chased this signal for about 3-4 weeks and then it suddenly disappeared. That was about 2 years ago and I have been monitoring to see if it comes back and nothing. I've tried googling to the end of the earth coming up with nothing. Anyone have any idea what this could be? Thanks for any help!
I have several video's of the signal also but I cant figure out how to attach them.
nd5y
Wichita Falls, TX
That frequency range would be Narrowband PCS (CN). It's probably not federal.
kv5e
T¹ ÆS Ø
ReFLEX is the protocol, you should see several more carriers in the DC area.
SkyPager
Arnold, MD
You are hearing what was once SkyTel's two-way paging network. Not sure who owns them now.
Four 10 kHz carriers centered on 940.220 MHz downlink; 1 carrier at 901.20625 uplink.
u2brent
OAMPT
KRWDPAXKRS1
FCC Search Results for 940.20 to 940.29
No Results in DC
MD Search Results
Call Sign/Lease ID​
Name​
FRN​
Radio Service​
Status​
Expiration Date​
1 L000013904 Southern Maryland Electric Cooperative Inc. 0002163400 CN Active 09/29/2024
2 L000031849 Town of Elkton 0027090091 CN Active 09/29/2024
VA Search Results
Call Sign/Lease ID​
Name​
FRN​
Radio Service​
Status​
Expiration Date​
1 KNKV204 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
2 WQQW517 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
3 WQVG782 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
4 WQWH391 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
5 WQWR702 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
6 WQXT200 Sensus Spectrum LLC 0015015019 CN Active 09/29/2022
7 WQYK264 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
8 WQZE436 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
9 WQZE443 Sensus Spectrum LLC 0015015019 CN Active 09/29/2024
10 L000024311 Sensus Spectrum LLC 0015015019 CN Active 03/19/2023
kv5e
T¹ ÆS Ø
OK, Sensus forward channel for their AMR telemetry system for meter reading. ReFLEX will have be in 1.875 second frames.
justinbucherj
Washington DC
But it wouldn't explain why I saw it every day for a month and now its disappeared. I look for this signal everywhere and I have never seen it again. I travel a lot too.
kv5e
T¹ ÆS Ø
Unless they are testing and have not commissioned the system yet. There could be several reasons why. That was the Skytel ReFLEX 50/25 band and Sensus now has spectrum in CN from 940.0000 to 940.2500 MHz
