96-v-folder help
RDCat
N.W.
win 96 put in 4 different" new"
folders, 1 of colorado metro in folder 1and another in folder 5 and one ski &eagle conty in folder "0"
when i save and re boot say folder "0"
i press prgm func prgm save exsiting folder to scratch "."
then hit enter,exit.
2-load "0"-now the question-it shows load from vscanner:0
enter if yes
nothing on 4th line like id hoped i put in on win 96 while on tag area?
i hit eneter confirm then it re boots and then it states the folder as
the text tag ski&summit county.....
why does the other downloaded folders show the bank name like broward -a folder i downloaded from pro96?????and not the ones i also just downloaded
thanks
hope it makes sense
ron
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
ron: i'll try to help...
i would recommend putting your files in consecutive folders... start at "0" thru "4".... on the settings page (the "title page", if you will, of each file make sure you have entered the information identifying the folder (this is what mine looks like: "metro.dsp.mp". i have about two dozen working v-folders, each with a tag that explains to me exactly what is in each)... that is the file i load in folder "0" AND is usually loaded in the working portion of the scanner....
when i need to listen to "metro.sehill" i know it is saved in folder "3" and when i am finished with it i put it back into "3". then load the file from folder "0","metro.dsp.mp". i go thru the button pushing to get there... thru the rebooting, etc...
i think, if i am reading you correctly, you are saving the file to the scratch folder then trying to load from the original folder... if you save to scratch you must load from scratch... i never use the scratch except to temporarily hold a file while i am fiddling with it....
hope this helps....
RDCat
N.W.
kinda helps
thats what i think im doing ????
Voyager
I use the 'scratchpad' folder as an 11th V-folder.
Whatever I want to listen to, I load that V-folder. When I want to listen to something else, I load that V-folder. If I've made any changes, I save the current V-folder before loading the next one.
You ARE waiting for it to save before hitting ENTER a second time after it's saved and CLR after that, aren't you?
It will show the file name as the 4th line on the opening display. (and only that line)
Joe M.
RDCat
N.W.
joe i am i just save my aspen regular folder to the "11"th folder if u will
then hit load to number say folder "0" for eagle/summit county here in colorado!
unitcharlie
i will start doing that voyager... i was under the impression that "ascratch" a volatile folder... cool.
ron: which files do you have loaded in which folders?
RDCat
N.W.
"0" folder-an uploaded folder of -vail cooper mtn-colorado
"1" folder an uploaded folde of - metro denver
2-regular -ca az nm nv --exsisting folder
"3"-exsisting folder--Tx.louisiana
"4"florida
"5"-uploaded folder--metro denver area
"6" uploaded folder-Las vegas
"7"-empty
"8" emplty
"9" uploaded folder---florida
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
401402,
Open a new template in Win96 and you will see in the Settings Page:
Welcome To
Digital
Trunking
Line four is blank purposely so that you may enter the file (or system) name. The entry on line 4 will be the displayed data during boot up or when accessing V-Scanner after pressing 1-SAVE or 2-LOAD, then a V-Scanner number.
RDCat
N.W.
ok that helps out alot-ron
