996 Failure-help
ff-paramedic
Elk Grove, California
Yesterday my new 996 stopped functioning. No trauma was inflicted on the scanner (before or after), this just started spontaneously. It worked flawlessly prior to this failure.
The scanner was unplugged and moved to another outlet in my room, then turned on. The two opening screens (996 info and copyright, etc) came up, but then nothing-it stays on the copyright screen only--no audio, no other screen activity, no response to any of the buttons. I tried reprogramming it with the computer, but the scnner will not communicate with the computer. Is there a way to do a reset, or any other suggestions? Is it just time to pack it up and send it back to Uniden?
Thanks.
