as soon as I turn the radio on, it says it goes to close call DND mode, then goes straight to close call only mode.
The only thing I did before I noticed this change was remove the speaker from inside (took both cases off in order to dash mount it, too tight of fit otherwise)
The squelch doesn't work either, since this change. No static when I open squelch all the way.
Anyone else had a problem like this? I have ver3 firmware.
