996 Questions On Display & Re Manual
BOBRR
Boston, MA
Hello:
Two questions for the 996 folks:
a. regarding the display on the bottom left
(and pertaining to their dwg in the manual)
Item 1, the Group Quick Key is clear.
But for item 2 which they call "Site Quick Key" -
what is the "0" immediately after the "S"
are the numbers following the two vertical dots the QK's that are active ?
is the meaning of "site" the same as "channel"
b. I noticed that the manual that came with the unit, and the manual that is downloadable from the Uniden site in pdf form are different. Unfortunately, neither seems to have a rev. number or date.
Which do you think would be the latest ?
Thanks,
B.
spooney
Indiana
S=System
S0: 1234567890 is for System Quick Keys 1-0
S1: 1234567890 is for System Quick Keys 10-19
S2: 1234567890 is for System Quick Keys 20-29
and so on thru S9: 1234567890
Remember to enable / disable System Quick Keys use (.No) then 1 then 1 again for example when using QK 11 (.No) is the shift key for all 2-digit System Keys
As for the owners manual I would use the one that came with the scanner
Hope this helps
