996P2 no longer communicates with Windows XP computer
kc9neq
Illinois
I have two (2) 996P2 scanners with Firmware 1.06.00.
They will no longer communicate with the front usb port on my Windows XP computer.
I was previously able to use the front usb port to program the 996P2's with no problem.
Nothing has changed with the computer and the usb port works
I am using the usb cable that came with the scanner.
I have tried a different usb cable but have same non connection results.
I am using Free Scan and ARC XT Pro on the windows computer.
Any suggestions?
lucky43113
Central Ohio/Pickaway County
Any suggestions?
I have the same scanner and I use win 10 sometimes if my scanner is on for a few days it will no longer be recognized all I have to do is turn the scanner off then back on and do the auto com search and it works fine.
kc9neq
Illinois
I tried that but it did not work either
iMONITOR
Silent Key
S.E. Michigan
Go to Computer Management, then Device Manager, then Ports, and check to see if the USB Serial driver is installed, and recognized. Then check the setup in your scanner software, to see if it's using the correct com port.
kc9neq
Illinois
This is what I have under the device manager.
eaf1956
Evansville, IN
Looks like a driver issue! Try uninstall and reinstall w/o deleting the driver. If that don't work uninstall and delete the driver then reinstall everything.
