I am trying to figure out why a 996T is getting horrible reception on the San Diego RCS system. It's an 800 simulcast system, and it was suffering low signal/broken reception due to an old VHF roof antenna install. After installing a new 800 antenna, the signal meter reads full, with an RSSI of around 500-600 on the control channel. When logging hits with FreeSCAN, I get like RSSI of like 300 on many channels, and even though the radio shows full bars, I get extremely broken P25, and scratchy analog that breaks in and out of squelch.
It's not a "too much signal" issue with the P25, as the analog stuff is all static and broken as well. My question is this......does the signal strength meter show the current receiving frequency of the active talkgroup, or is it always the control channel?
The weird thing is when I hooked up my 396XT on the same antenna/cable/etc, it gets the same signal strength, but the reception is MUCH BETTER, not breaking in and out. Also, when using my on scanner antenna indoors, the signal will be like 1 bar, but I still get unbroken reception, even though the 996T next to it is full signal and broken. Can scanners go bad with age? The attenuator is not active, checking all the menu options, can't figure this problem out.
This problem exists on the LOWEST signal 800 system being monitored, the other two get MUCH BETTER RSSI and signal, and do not suffer any choppy reception or simulcast digital breakup.
Paul
Paul
