996t and gps
pinellasfirefighter
Banned
seminole fl
which Garmin Etrex vista there was 2 i found the vista and the vista cx.. do i need any cables to go with this or does it come with everything i need?
UPMan
In Memoriam
Arlington, TX
I believe the cx is USB only (but check to be sure). If so, it will not work with the 996. The 996 will only work with GPS that have standard serial output. There is a list of known compatible models on the 996 wiki page. You will need the GPS serial cable specific to your GPS model (it is the same one you would purchase or need to connect the GPS to your PC's serial port).
newbie
St Clair, Michigan
Not the C or CX plain jane vista (no color). I have had this gps for about 6 years. Used mostly for hiking and hunting.
I found that the windshield suction cup mount bracket works the best for my truck. The "movable" mount for the dash really does not work good as the base pads do not like to be moved.
You can also get a combo serial / cig adapter power cord but the unit come with a serial cable,
vista
http://www.thegpsstore.com/Detail-Garmin-eTrex-Vista.asp
combo cable
http://www.thegpsstore.com/detail.asp?product_id=GL0287
suction mount
http://www.thegpsstore.com/detail.asp?product_id=GAX10361
bigred04
can some one tell me if this gps unit will work with the 996
Magellan RoadMate 300R GPS
UPMan
In Memoriam
Arlington, TX
According to the O/M, the RoadMate 300R unit only supports USB connection to a PC. It does not offer NMEA serial output, so it will not work for this application.
