I have had an issue pop up on my two month old 996T. I have the backlight set to "low-green" since I work midnights and the rest of my radio equipment has green lighting. At some time during the shift, and sometimes more than once, the backlight will change to high-green. When I push the Power/volume selector, the radio thinks that it is still set to low and changes to medium-green. I then have to cycle through high-green, the red settings and off to get back to low-green.
I have the auto dimmer set to off and I have the orange dimmer wire taped off so it will not inadvertently come into contact with either a load or ground.
I thought I had seen another post on this problem but I don't recall seeing a fix. Any suggestions
or do you think that a trip back to Uniden is in my scanner's future?
