996t display
abbadabbado
port richey
just had power falure with lasted about 30 minutes when power came on turned on 996t all i get is start up screen uniden america all rights reserved ect will not go to scan or search will not bring up any programing any suggestions
CoolCat
Hopefully you have your setup backed up; if you do then I would try a factory reset (hold down the 2, 9, and HOLD buttons while powering up the scanner). Not sure if that will fix it, but it may be worth a try (and you've got nothing to lose if your programming is backed up).
Good Luck :)
