996T with rebanding
mmartinfan
Banned
In a house in Ohio
Quick question with the Franklin County rebanding systems
All I have to do is input the 4 or 5 control channels and it will scan the system. I don't have to make some sort of whatever a custom band plan is. Correct.
Same thing with Marcs and the new IP-Marcs
The new MARCS IP doesn't require a custom band plan table since it is true P25. The Old MARCS needs one.
I'm not familar with the Franklin Co. system but just looking at the RRDB I think you will need a custom band plan table.
There are plenty of folks in that region on here and they can help you out.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
And your firmware must be up to date. The older firmware in the 996T can't handle rebanding
The details are in the Uniden TWiki - and note that you must follow all the instructions to the letter, assuming you need to upgrade your radio
This article tells you how to check your radio and the links for each DMA scanner's upgrades...
Updating the Firmware in Uniden DMA Scanners - The RadioReference Wiki
Mike
