Hi everyone,
I've got a BCD996XT and am using ARC XT Pro. I am trying to get Wyolink working correctly. I used the info download from RadioReference.com option and now sometimes hear WYDOT, but never WHP. I have a xts5000 that can hear the WHP traffic and they are communicating. but it is not being heard on this scanner (and before you ask its not encrypted). After much research I have found some settings I don't understand.
1. Under system "trunk system parameters tab". How do I figure out the "fleet map"? I know Wyolink is a system type 2. Do I need anything here?
2. Under sites - General tab - there is a check mark in control channel and the MOT bandplan is set for 800MHZ standard- only problem is WYOLINK is VHF and from reading the manual it says it needs a base frequency/lower and upper step and an offset. I cannot seem to find any information on where to get these missing values, or do I need to worry about them with the control channel checked?
I found some information on programming the Pro96 scanner but that information does not work in the 996XT as it doesn't allow for a 2.5Khz step in this model. Any help that can be provided would be most appreciated.
Thanks and 73's
Yancey Allison
N7RON
Thanks and 73's
Yancey Allison
N7RON
