badbones
Recently purchased 996xt. Originally the communication between scanner & laptop worked using ARC programing. Then for some reason the link could no longer be established... This happened within the first day of use... Have tried different computer with same results... Tried Free scan software and still could not establish comm link... Scanner set up for comm link is basically setting serial port baud rate in settings menu.. I have tried 57600 & 11520 being careful to match program settings.
No luck! Have tried using rear port on scanner with different cable, but no luck there either. The fact that it originally worked for first day or so tells me I inadvertently toggled something, but I am at a loss as to what... Is there any other menu items or keyed entry combinations that would affect the comm ports on scanner? Any help greatly appreciated....
