FrankRenda1
- Joined
- Sep 11, 2009
- Messages
- 41
I have a Problem with the Rebanding of the Suffolk County Trunk System
My Setup Includes.
Bearcat 996XT (Firmware is 1.04.00)
Freescan
New Freqs & Custom Bandplan from RR’S & Wlie
After Updating the 996XT with the New Information.
There seems to be Some Sort of Glitch while Scanning the Talkgroups that I Programmed into the scanner. Talkgroups that are NOT Programmed in are Showing up with the ones that ARE Programmed in for Example.
The Following is programmed in to My Scanner as.(Fine so Far!)
57776 6th Pct Dispatch
54576 4th Pct Dispatch
48240 Car to Car
60848 Command Band
But These ARE NOT Programmed in! But Show up Anyway as.
In the Settings Menu the Display Unit ID is Turned Off.
Also any old settings where Erased then Reprogrammed.
Still the same Problem!!!
Any Help would be Appreciated
Frank
My Setup Includes.
Freescan
48240 Car to Car
60848 Command Band
Frank
