BC346XT: A/c Power Adapter ??? for the 346xt
Greetings again folks I just bought a 346xt off of ebay it does not have the org A/c adapter so I did what the Wiki page on here said to do,So went to Radio Shack and bought a 6 volt 800ma with the B tip, now I keep reading different things on here that says don't use a aftermarket adapter on these radios, if So my ? is can you use the RS one or should get the uniden one, The radio will be here on Wednesday I hope and don't want to break it by using the wrong adapter.
Thank You Folks For All The Help You Give
MarkWestin
Caribou, Maine
The original AC adapter is the Uniden AD-1001 AC Adapter. It is available at most dealers including ScannerMaster and HRO for about $25.00 plus shipping. The Radio Shack adapter is probably OK to use but it could produce electrical noise (if it is a switching power supply) since it is a generic power supply. The original Uniden AC adapter is a switching power supply, but since it is designed specifically for use with a scanner it has filtering to reduce or eliminate the electrical noise. As for what the previous poster said about the Eneloop batteries and the Maha charger, I agree totaly with them. I own three of the MH-C9000 chargers and a large number of the Duracell rebranded Eneloop "precharged" or "low self discharge" batteries which I am very happy with. I also never charge batteries in any of my scanners. I almost always use the original Uniden AC adapter(s) when using my scanner(s) in my home and they run virtually continuously.
