A charger that charges only 3 batteries?
Oldglide
Metro Chicago
Does anybody know of a charger that charges 3 batteries at a time instead of the normal 2 or 4? 396T battery thing. I refuse to charge batteries in the unit.
talkpair
Clinton County, MO
Thanks for the links.
It seems more and more battery powered devices are using an odd-number of batteries nowadays.
All the chargers I own are for an even number of batteries
n0doz
Metro PHX AZ
I picked up the LaCrosse charger a couple of months ago... GREAT unit. Analyze, rehab, charge, etc. all in 1 relatively inexpensive unit. Does AA or AAA, from 1 to 4 at a time - and you can do a different function on each battery.
Danny6569
Riverside new jersey
batteries
Try the energizer 15 min charger, you can put 1 or 2 or 3 or 4 in that charger, i usually charge 3 at once, you dont have to put all 4 in it.
JASII
I usually use my 396XT with a 12 volt cord, but I am tempted to get one of the chargers mentioned here.
I personally recommend the Maha C9000 that has been described above.
I have been using this charger for a few years now and it is wonderful. You can charge single batteries and I like the discharge / analysis feature as well.
K
kb0nly
Guest
X2 on the Lacrosse BC-700, or the BC-900 if you want a little more speed... The 700 has charge rates of 200ma, 500ma, and 700ma... The 900 model adds 1000ma rate and also 1500 or 1800ma when charging a PAIR.
In my opinion the extra cost of the BC900 isn't worth it unless you like burning up batteries. Low and slow is the best. I will sometimes toss a pair in at 500ma or even 700ma, but most of the time i just let it charge them at 200ma.
I have a 396T and four sets of Tenergy 2600mAh batteries from BatteryJunction.com along with my BC-700 make it painless.
j3nitnweed
Bonney Lake
I use Rosewill model RGD CT505, it will charge 1 to 4 AA & AAA rechargeable and regular alkaline batteries. Found it on Newegg.
h8tdigitalradio
Six Feet Under
Hello,
Another option is Maha Energy's MH-C401FS. It can charge 1-4 AA or AAA NiMH Batteries. It also has a slow or fast charge switch.
73
Dave AKA The Tripzter
ArgoGirb67
London Ontario Canada
Ive been through several CH1HR-2 (Energizer 1 hr,1-4 batts.)I was sent a 15 min charger as a replacement(lifetime warranty) .I find it wont charge many bats.Also with one Led,you must get voltmeter out to determine which didn't charge.(it will charge the other batts.when flashing)I put the "bad"cells in the 1 hr charger and they charged fine.I find the 15 min charger doesnt charge completely,I only get about 3-4 hrs from 2450 mah cells,8+hrs use when charged in 1 hr charger.If you buy energizer KEEP YOUR RECEIPT!,call the 800#,mail it in(i keep the batts,have a bunch now)
Dave
Dewey
{SNIP}
{SNIP}
You piqued my curiosity with this statement. I've been using the Maha MH-C9000 since it first came out. I always run my brand new batteries through the break-in cycle before I put them in service, and it seams to really help. I've been using the PowerEx 2,700's for many years, but started cycling in the low discharge Imedion 2,100s last year to replace the PowerExs. Anyway, when I put the PowerEx 2,700s through an annual, or bi-annual break-in, the Maha MH-C9000 has consistently killed them. I'm scared to put the newer Imedion 2,100s through a break-in cycle, and will only occassionally give them a "Refresh/Analyze". Is something wrong with this picture... the Maha MH-C9000 killing the higher capacity PowerExs if they're put through "Break-In" after a year or more of service life?
I don't wan't to hijack the thread, but like I said, the statement piqued my curiosity, and there seems to be a lot of Maha MH-C9000 user here. If need be, I'll relocate over to "General".
Dewey
K
kb0nly
Guest
Dewey
In my experience the older the battery the more susceptible they are to damage from overcharging or overheating. When you cycle them and they get killed do they also get HOT? I have some old batteries from one of the kids toys that i tossed into my BC700 on a refresh cycle and selected the highest charge rate because that also selects the highest discharge rate, i just wanted to cycle them fast and see if they were any good, they got HOT on the 700mA charge rate. And consequently two days later when they were dead they wouldn't take a charge again. I even put them in a slow dumb charger to see if it could force a charge back in, no go, after a few hours they were just hot and not holding a charge.
I don't charge over 200mA unless i really need to, and then i usually only use 500mA. The Tenergy 2600mAh batteries i got from BatteryJunction are holding up really good cycling through the scanner and tossing in the BC700 at 200mA. They all come up to full capacity and last a long time. Time will tell how long they last before failure.
Heat is the ultimate enemy of NiCD or NiMH batteries. I'm not familiar enough with Lithium but i assume they would be affected as well. I have some rechargeables floating around that are years old and still work great.
jmm346
I use this one here. It was purchased from Target a few years ago, don't know if they still carry it.
It has individual charging indicators and also includes a USB charging port.
Powered by Google Docs
sjlamb
Sarasota County, FL
15 minute chargers (such as the Energizer) will dramatically shorten the life of rechargeable batteries. Compared to the LaCrosse and Maha chargers repeatedly recommended by others in this thread; the Energizer charger would make a fine gift for your most hated enemy.
