A couple of basic questions about the SDS100
KB2GOM
Rensselaer County New York
I have the SDS200 and love it.
Now I'm thinking about a portable, database-based scanner. My understanding is that the 436 cannot be run off housepower and scan at the same time, yet my 125AT can.
Soooo, can the SDS100 be plugged into house power and scan? Or must it be unplugged and run off battery at all times?
Second question: I plan to use this scanner when traveling . . . recommendations for a good all-round antenna, or will the stock antenna do?
werinshades
Chicago , IL
Yes it can charge while on. The default setting when you receive it is set to off, just have to go into the menu, battery options and change it.
Antenna choice is more band specific, and I use the stock antenna and have had good luck.
KevinC
OBT Matters
Super Moderator
Home
Interesting, mine has no option to charge while turned on. Maybe you have a different FW version.
tvengr
Well Known Member
Baltimore County, MD
The BCD436HP can scan using external power. It cannot scan and charge at the same time using external power. The SDS100 has a setting permitting both scanning and charging at the same time using external power.
KK4JUG
GA
For the SDS100, there is a menu setting that will toggle the "scan and charge" feature.
Omanzz
Massachusetts
SDS100 runs on DC adapter and scans at the same time
Chris0516
Pittsboro, North Carolina
I have (3)AA Rechargeable batteries in my 436HP. I also have a USB going from the scanner, to a USB port on my PC. The USB cable serves the dual purpose,of. Both data transfer, and recharging.
