A different county radio traffic
mryan36
They went digital a couple years ago. They use the Project 25 Phase II, the same that my county uses, Pottawatomie. I'm 190 miles from Edwards county.
Is it possible to get the county's radio traffic in my county??? Do you know how it's done? Please let me know. I don't see any info about the 453.7375 repeater.
dave3825
Suffolk County NY
So since it's a statewide system, It all depends how the system is configured.
So these sites are by you
2 (2)009 (9)St George / FlushPottawatomie851.600852.3125c852.6125c852.9375853.1875853.650
2 (2)053 (35)WamegoPottawatomie856.4875856.9875c857.2375858.4625859.2375859.7625
and this is by your folks.
1 (1)020 (14)FellsburgEdwards851.600852.3125c852.6125c852.9375853.1875853.650
If the tg's in Edwards County only affiliate with that site, then you will not receive any of those tg's. If any of the tg's in Edwards County do affiliate with your two sites, or any other site within range of you that you can recieve, then you should be able to listen. Easiest way to tell would be to add the Edwards tg's to your scanner and all sites you can receive and see what you get.
Edwards County​
DECHEXModeAlpha TagDescriptionTag
7082c4DEdwards Co SOSheriff DispatchLaw Dispatch
7072c3DEdwards Co FireFire DispatchFire Dispatch
6862aeDEdwards Co EMSEMS DispatchEMS Dispatch
7092c5DEdwards Co EMEmergency ManagementEmergency Ops
7102c6DEdwardsCoEvent10Event 10Interop
7112c7DEdwardsCoEvent11Event 11Interop
7122c8DEdwards Co TacTacticalInterop
mryan36
Other than just putting in the frequency with FreeScan, do I change any of the settings?
dave3825
Suffolk County NY
If you have the system in your scanner, and just want to try adding the talk groups, you can do that. You already have the site closest to you in there so if you add the tg's and dont hear anything, you could try adding other sites near you that you may receive.
