bob-k
Hi all, on the SDS100 on the display on top left what is the meaning and Function of FO: - SO: & DO: I am guessing it’s a quick key? I have toggled the 2 and the 3 on and off when I do there replaced by a * but I cannot get other numbers to display and this only on the FO: line I have no idea how to manipulate the SO: or DO: lines.
What is the icon between Priority and weather icons right? Looks like an eyeball
I find most info when I refer to either Sentinel or BCD436HP data! what is the best detailed book I can het I realize it’s too soon for my new toy but there are great similarities between SDS and BCD!
This is a great Radio very pleased, but reception is such I feel I can improve it by buying & using a better antenna!
I’d like to keep the Connection type as I feel it is more water tight then BNC (am I right or wrong?). I seek to buy a magnetic base that I can put same antenna on the car base that I use on the scanner! Let them both share this antenna. I do mostly fire band work, so I need best coverage on both 800MHZ and 155MHZ frequencies!
Thanks guys
Thanks guys
