This bus bar runs to my whole house main electrical grounding bar......so everything will be grounded
at one point.
A lot of hams tend to over-think shack grounding and create their own ground loops, which it sounds like you're doing here. If you ohm out the power supply for your equipment, which is likely equipped with a three-prong power plug, that is already grounded to your service entrance. And there's likely an external chassis grounding point on the power supply. Ohm that out from the ground pin on the power plug to the chassis of the power supply and you'll likely find zero ohms.
All that's required to eliminate potential between your radio(s), tuner(s), etc is to run a grounding wire from each of those (daisy chained) to the ground point on the power supply and you're already connected to your service entrance grounding point. Why are you creating a ground loop with a second grounding circuit? The only reason to do what you're doing is if your station equipment runs off a battery so you have a floating ground, or you have some sort of cheap power supply with just a two-prong AC plug.
I would urge you to check this out with your handy ohmmeter before you go to great lengths to create a ground loop. There's a reason on AC power why only one neutral-ground bond is allowed in the system at the service entrance, and all subsequent sub-panels are not bonded. Power only flows on that service ground in the event of a fault, and it flows to that common grounding point. You don't want it flowing in loops, following the path of least resistance to get there - that will create differences in potential.
When you think of electrical grounding in AC power systems, reduce it to the simplest terms - every electrical item in your house or shack is grounded but there's only one path to that common ground from any item. Don 't create two paths or you got a ground loop, same as bonding the ground to neutral in a sub-panel with split-phase power.
RF grounding is different and that can't be bonded to your electrical service ground. So is antenna masts and towers different, they normally have their own grounding system to divert lightning or static buildup without running it thru your electrical service ground.
