A little help please...
scannerbum
Central IL.
I finally bought myself a 2096 yesterday. However not sure if I am getting it right?
This is what I am interested in hearing.
217 D09 Sangamon (Springfield- South) 866.40000 866.92500* 867.45000* 867.97500* 868.86250
230 D09 Sangamon (Springfield-Hilton) 858.21250 866.48750 867.32500* 867.85000* 868.37500*
IDNR - Statewide Talkgroups
DEC HEX Mode Alpha Tag Description Tag
1280 500 D INDR ?? 1280 IDNR - unid (10/07) Law Tac
1281 501 D INDR ?? 1281 IDNR - Region ?: Car-to-Car (units 7F16, 2F25, 1F units) Law Tac
1285 505 D INDR ?? 1285 IDNR - unid (10/07) Law Tac
4126 101e D IDNR ?? 4126 IDNR - unid Law Tac
4132 1024 D IDNR3?? 4132 IDNR Region 3? - Car-to-Car? (2/08) Law Tac
4133 1025 D IDNR ?? 4133 IDNR - unid (heard "Pick me up at Wireless USA in Springfield" 12/07") Law Tac
4134 1026 D IDNR ?? 4134 IDNR - unid Law Tac
IDNR - Region 4 Talkgroups
7400 1ce8 D IDNR4 ?? 7400 IDNR Region 4 Law Tac
7401 1ce9 D IDNR4 ?? 7401 IDNR Region 4: Talk Around? (heard 4F35, 4F36 11/07) Law Tac
7402 1cea D IDNR R4 C2C IDNR Region 4: Car-to-Car (*1/08) Law Tac
7403 1ceb D IDNR ?? 7407 IDNR - unid Law Tac
7408 1cf0 D IDNR ?? 7408 IDNR - unid Law Tac
ISP District 09 - Springfield Talkgroups
13004 32cc D D09 Disp A Illinois State Police: District 09 - Dispatch A Operations (*) Law Dispatch
13005 32cd D D09 Disp B Illinois State Police: District 09 - Dispatch B BOLO's (*) Law Dispatch
13006 32ce D D09 Disp C Illinois State Police: District 09 - Dispatch C (*) Law Dispatch
13017 32d9 D D09 Detail A Illinois State Police: District 09 - Detail A? Law Tac
13018 32da D D09 Detail B Illinois State Police: District 09 - Detail B? Law Tac
13019 32db D D09 Detail C Illinois State Police: District 09 - Detail C Law Tac
13028 32e4 D D09 IREACH*P Illinois State Police: District 09 - I-REACH Patch? Interop
13034 32ea D D09 ISPERN*P Illinois State Police: District 09 - ISPERN Patch (*) Law Talk
13040 32f0 D D09 Local*P Illinois State Police: District 09 - Local Patch?(*heard doing speed trap 10/07) Interop
13046 32f6 D D09 Car2Car Illinois State Police: District 09 - Car To Car (*) Law Tac
My questions - 1. Do I need all the cc in D-9 from both sites and if so in the same banks?
2. If both towers do the same thing is one better to have than the other?
I put T217 in bank one and T230 in bank 2. Early in the day bank one seemed to be working fine with some static. Then is fizzled out and bank 2 started pulling in the conversations better. I am 1 mile from the first cc's I listed and about 5 miles from the second.
Need some starcom 101!
timmer
Springfield, Il
I have a pro-96 which is basically the handheld version of the 2096. All I have programmed into it is two cc freq's. 866.925 and 867.325. I hear 13004, 13005, 13017, 130046, 17009, 13007,13011, 13000, 17011, 17040, 7311, and still a few misc. others. mostly interested in d-9 state police. I too am interested in any replies on how to better set up my scanner. I know I can't get any 700mhz cc's with it. I don't think there are any of those in d-9 except for cass and maybe menard county. I am still experiencing quite a bit of distortion/digital noise on an intermittent and unpredictable basis. Don't know if it is simulcast distortion, bad reception or what. Still wondering if a gre scanner would be better, but I saw the other day a post that said they are not. Any comments/suggestions welcomed.
RoninJoliet
ILL
I have a 2096 and im 20 miles from the T125-Grundy Co here in Joliet, the 2096 has a RS-20-176 ground plane up 30' with RG6U lowloss coax and receives "full signal-98%" from this tower hearing D5,6,17,21...Using a rubber duck on the second story of my tri-level on my PRO96 is OK but as mentioned in your posts still results in signal loss and machine-gunning but NOT on the 2096...Just my 2cents...PS: I also have the GRE500, its maybe about 10% more sensative than the PRO96 but still see's some drop-outs upstairs with a RS 800 rubber duck....The proof is in the outdoor antenna...
chgomonitor
Silent Key
Chicago
Starcom Sites
Yes, unless you have a multi-site capable scanner like the Uniden 996 then each Starcom site should have it's own bank allocated in the radio. Treat each site like a separate system, though the large talkgroup list is common to each - within each of the 3 zones (North, Middle & South), plus the statewide groups. Make sense?
chgomonitor
Silent Key
Chicago
Springfield sites
Yes, the Springfield arrangement does seem a little odd. I had assumed that perhaps the Dist 9 HQ tower would only have state police and/or academy traffic assigned. But from what we've seen while we have been there - that doesn't seem to be the case. They seem to work like all the other sites. What you'll hear on each seems to depend solely on which radios tuned to which talk groups are currently affiliating with each site.
Both the Hilton and D9 sites seem to have excellent ground coverage geographically. While 800 MHz propagation is generally weird, we had no trouble copying either site from 10-20 miles away.
The Springfield City TRS seems even better, I can usually copy it about 3/4's of the way out to Bloomington/Normal, and even from there when I find a sweet spot.
An 800 MHz gain or outside antenna may help a bit.
RoninJoliet
ILL
On the RS2096/PRO96 you can put multiple CC'c in one bank, seperate them with a VHF-Analog freqy set to "FM" and it works fine...I have two 800mgz systems in one bank here my local system and the local prison...They must be Motorola Type11 not EDACS....
