A mobile mount for my SDS100
emscapt9816
Retired, but somehow working harder now...
Coconut Creek, FL
Looks good Frank! Have you considered a BNC connector for the antenna connection? It might make it a little easier when mounting or removing the radio.
vagrant
ker-muhj-uhn
California
I use Ram and or Lido mounts that affix to a bolt on the seat floor and have a flexible arm. They're pretty solid and similar to his setup. I go off road and no problem. The only time it disengaged was when I was stationary and hit from behind around 40 MPH. One of the arms holds a Yaesu 400XDR control head and Kenwood 480SAT control head. The other holds a handheld scanner.
jonwienke
More Info Coming Soon!
VA
I prefer the RAM finger grip for the scanner cradle, with a ball mount attached to the back. It holds the scanner with a lot less play than a mic clip. And the scanner doesn't have to be in a case, so it can run a bit cooler.
emscapt9816
Coconut Creek, FL
Jon, will the RAM finger grip hold the SDS100 with the big battery?
