A new FAQ?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Currently we have the same data about moving playlists around, deleting, Skywarn and other topics replicated in these 4 articles.
PSR-700 - The RadioReference Wiki
Pro-107 - The RadioReference Wiki
Pro-18 - The RadioReference Wiki
PSR-800 - The RadioReference Wiki
IScan Installation and Tips - The RadioReference Wiki
(does this also apply to the Pro-18 and PSR-800?)
We have FAQs for the Uniden DMA and Object Oriented Scanners that have keypads - it seems to me that it's time we had a similar FAQ for these 4 scanners as well. It appears we have enough data to start one - if someone who is very familiar with these scanners would take a look and clean up this mess, I'm sure the newcomers would find that very useful. To be honest, I don't know what in these 4 articles is common to all 4, or just to the 2 analog and 2 digital scanners
The most common questions- and answers - could then be gathered in one place, making them easier to find. Anyone?
best regards..Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'm bumping this one up - and surprised no one answered...
Anyway, since I don't have any of these scanners, there's a few questions that need some answers...
- Do the PSR-700, PRO-18 or Pro-107 use 'Scan Sets' like the PSR-800 does?
- Is the process for loading the USB driver for these radios the same as what is already documented in the Connecting Scanners via USB article?
- The IScan software works on just the PSR700 and the PRO107? Where do you go to check to see if there's a new version?
- Does the Pro 18 use the same software as the PSR800? Where do you go to check to see if there's a new version?
- Do any of the tips found here actually work with these 4 scanners? If so which ones?
- Where do you go to get new firmware? What is the process of loading it? (I think there's a sticky for this somewhere...). I see the one just released for the 800, but what about the others?
Putting this stuff into one place will help newcomers find their way around - especially since these scanners don't have keypads like most others do...best regards..Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
OK I've pulled everything apart in the wiki that applies to these scanners, and gathered the tips in one place - you can find it here
GRE/RS PC Object Oriented FAQ - The RadioReference Wiki
One question that is sure to come up has to do with rebanding - if it's just downloading from RR and both software packages (EZ-Scan and IScan) handle it, that can be added, as well as any other related tips...the rest is up to you
best regards..Mike
