Nothing high speed or low drag here, just one simple way to mount a handheld scanner/radio or just about anything with a belt clip that does not weight a lot.
Another fellow posted this tip for using a zip tie into a vent, and I tried it and it works well for my needs. I'll admit this is a lot easier because I use Eneloop AAs (last for days before I charge then again) and I do not use an external antenna, but it could still be done neat enough with this mounting arrangement.
Now the scanner can swing a little if I need behind it, but my truck has the automatic headlight control so it's very rare that I actually need the headlight knob that is behind it. The truck is a 2002 GMC 1500 with a standard cab, and since there are times I carry a woman and a baby seat I can use all the room I can get
