I've been messing with these radios for a little over a year now and have ran into several little snags along the way. Normally a few hours of work and I can set my stations like I desire and be on about my business. Now I have this new Firmware that doesn't make sense. Its N5R2205, nothing more than that number. For some reason I can not add any of my normal frequencies and I get the same error "Pasted memory # is not compatible with this radio because Frequency 470.###### is out of supported range". I know I am well within the limits of the radio it's just a little strange to see it give this error. I'm looking for anyone that might have a fix or know another way that I can force the radio to eat my channels.
First, I will assume that your firmware is N5R2405 instead of N5R2205.
There is 1 byte that CHIRP looks at to determine if the radio is a VHF/UHF model or a VHF/220 model. I suspect that this byte is set to an incorrect value for your radio (I've seen this several times before) and CHIRP is being fooled into thinking your radio is a VHF/220 model. From the firmware version I can tell that you definitely have a VHF/UHF model.
If you can enter frequencies in the range of 220.000 to 260.000 MHz, then this is the problem.
Assuming that this is true, the way to fix it would be to get this byte changed to the value that CHIRP expects to see for a VHF/UHF model. This can be done in several ways. The easiest is probably emailing your CHIRP Radio Image file to me and I will change the byte and email the file back. Email your CHIRP image file to: uv5r [at[ kc9hi [dot] net
Jim KC9HI
