AA Co Fire Dept Questions
BarnacleBill
Pasadena, MD
Here are some questions that I hope someone can answer.
1) What is the technical different between "Paramedic", "Ambulance"
and "EMS"?
2) What is the technical different between "Engine" and "Truck"?
3) What kind of unit is "FM865" and "FM866"?
4) What is the purpose and heirarchy of a "Battalion Chief"
and "Division Chief"?
5) What is "Status 6"? I assume there are other statuses.
What are they and what is their meanings?
mlevin
Baltimore, MD
1: EMS refers to the emergency medical system as a whole. Paramedic is a vehicle with at least one person traiend as an advanced life support provider (ALS). An abulance is a vehicle with only an emergency medical technician. This is a basic life support (BLS) level of care.
2: An engine is generally used for water. This is often called a pumper. This is the truck that has all of the hoses hanging off the back. A truck also called a hook 'n ladder is used for rescue and ventilation on the fireground. They carry alot of tools that the engine doesn't.
3: Can't tell you for sure but FM usually means fire maintainence. Don't know exactly what kind of truck it is, but it most likely belongs to the county shop.
4: Most departments are broken into a number of divisions. Each division contains a number of battalions. Each of these entities is lead by a chief.
5: Sorry can't help you there.
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
Just for giggles, I thought that I might add a few comments to Mo's post
1. To further define this, Advanced Life Support providers (Paramedics)can start IV's, intubate patients, cardiovert, and the like. Basic Life Support providers give minimal care, such as oxygen therapy and the like.
2. Engines carry water, hose, and a small amount of ladders. Trucks are usually easily distinguished by the 75' to 135' elevating ladder on top of the rig. Some trucks have a platform on the end of the ladder that allows the personnel to stand in them, which other trucks simply have a ladder.
There's also a "quint", which is a ladder truck that can perform all the functions of both a Truck Company and an Engine Company.
3. FM also sometimes stands for Fire Marshal, but I'm not sure about AA in particular.
4. Mo's right ... a Division Chief is in charge of several Battalion Chiefs.
Hope the helps!!
BarnacleBill
Pasadena, MD
Thanks for the replies guys. I'm learning more and more.
Obviously I was wrong but I thought a battalion might be
senior to a division. Thanks for straightening me out.
BoxAlarm187
Old Dominion
8) No problem, let us know if there's anything else you have a question about. Many of us are not only scanner buffs, but also in fire/EMS/law enforcement, so we can usually give you some pretty accurate answers to your questions.
Admin0140434
Anne Arundel County, MD
FM in aaco is fire marshall... you will only hear these units dispatched if the batallion chief/police dept believes arson is involved.
status 6 is availabe/on the air ready for calls
INDY72
Indianapolis, IN
A basic listing of equipment in Fire/Rescue:
Truck- Can refer to any of many such as a crew truck, an ambulance (also called a bus) Usually it refers to a general purpose unit such as a pumper, or a support vehicle with lighting, tools, etc.
Engine- Usually refers to a pumper truck, though can applie to any used to fight fires.
Pumper- A fire fighting vehicle that has a limited capacity tank for water, a pumping system, hoses and some ladders, and tools.
Tanker- A fire fighting vehicle that can consit of a single unit combined engine and tank, or a towed tank trailer for storage of water.
Ladder- A vehicle that has the primary purpose of carrying a large elevatable ladder for fighting fire/rescue at higher elevations than a small man portable ladder. Some of these units are also equipped with a pumping system, and iether a "cherry picker", or other device with a water cannon.
Rescue- May be iether a small (light) or large (heavy) vehicle with the sole purpose of performing, and supporting rescue/medical operations. These may be equipped with BLS, or ALS equipment/personnel. There are a few combination units that are called Fire/Rescue which combine a pumper with a rescue unit.
Brush- These are very specialized units soley for off road fire fighting, they may be desinged around a 4X4, or a large heavy truck.
Car- Umm duhhh... LOL usually a commanding officer's vehicle.
Squad- A multiple personnel carrying vehicle for carrying a squad or larger unit.
Command- Usually a Mobile Command Unit, which functions as a rolling communications and command center, essentially a rolling fire department.
Ambulance- Again duhhh. An EMS vehicle for the treatment, and transportation of patients to an advanced medical facility. Usually an ALS vehicle with paramedics,.. though some are only fancy BLS rescue units.
Then you have the fun ones that are mission specific, such as foam units, airport units,... and the HazMat units... Hope this helps some.
Llwellyn
Brooklyn, Maryland
and "EMS"?
1) In AA County, "EMS" refers to the EMS lieutenant on duty for the battalion. Each shift has a Battalion Chief (above a fire captain) in charge of the fire apparatus and personnel in each battalion, and an EMS lieutenant in charge of all EMS apparatus and personnel in each battalion. AA has 4 battalions, three shifts per day.
3) FM stands for Fire Marshal in AA or Annapolis city. These are law enforcement officers who investigate fire-related crimes. They are dispatched for incidents where arson is suspected, and they are sometimes auto-dispatched for big boxes or dwelling fires.
5) Status 6 for fire apparatus means on the air, available for calls, in their first due area. There is also Status 7, which is on the air, out of first due, unavailable for calls in their first due. There is Status 8, which is going off the air, out of service due to mechanical problems. Status 1-5 are used but are not called out loud, they are used in quarters and for special reasons.
The other questions were answered pretty thoroughly by the others, so I'll leave them alone. You can look up pictures of apparatus to see the difference at the Glen Burnie VFC apparatus page.
http://www.toad.net/~gbvfd/station_33.htm
