TinEar
I've noticed this a couple of times, most recently last evening during the double shooting in Glen Burnie (Freetown). When Trooper helos respond to a fire department call they generally can also be heard on the old 154.34 mHz freq in addition to Talkgroup 48 (when they use "B") on the trunked system. However, at times, there are transmissions on 154.34 that are not on TG48. Last evening I heard several transmissions from Fire Alarm to Trooper that were only on 154.34 but Trooper's response was on both places. Why would they do that? Is it just a mistake? It obviously means that Trooper is monitoring both TG48 and the 154.34 frequency but I can't understand why they would do that. Any of you fire department guys have a clue about this?
Speaking of AA County comms...Have you noticed that many times the first word or first syllable of a word when someone starts speaking is cut off? I've always assumed the operator started speaking before fully keying the mic. Not so. If you monitor both the talkgroup and the frequency in a conventional mode on a different radio, you only hear the cut off word on the trunked system. It's all there while monitoring the frequency in conventional mode. There is something about the trunked system that requires a longer wait before starting to speak. I haven't really checked this on other systems than AA County but I'd be interested to know if this is common to all trunked systems or just here on Anne Arundel's system.
