Like I said the weather works but I was listening and it's only weather reports from all over Missouri. I'm in Kansas. The big fire was also in MO. Why would it only pick up stuff from another state?
Since the weather works, that suggests either antenna (including scanner-location), or programming. Since KI7HYI has already asked about the antenna, I'll ask about programming...
If you programmed the frequencies manually (instead of downloading them from RR into the scanner), is there any chance that something got goofed-up, possibly accidentally flipping adjacent-digits or something?
Also, I don't know what squelch is open means. Turned up or down?
"Open squelch" is when you turn the squelch-knob to the position that allows the radio to receive all signals, often resulting in a "white-noise/static-noise" sound. Usually this is done by turning the knob to the left/counter-clockwise.
"Setting squelch" is when you choose the desired frequency in the scanner/radio, and then first move the squelch-knob to open-squelch, and then move the knob in the other direction slowly until you reach the position where the static (or unwanted stray-signal) becomes quiet.
"Full Squelch" is when you turn the squelch-knob as far away from "open squelch" as is physically possible, usually by turning the knob all the way to the right. This limits most signals except very-strong and very-close signals, and is usually the last thing most people want to choose as a setting.
Sorry to sound so doofy but I really am a newby at this.
We all started learning at some point, don't get frustrated, just stay inquisitive.
Hope this helps,
