AACo Fire Talkgroups usage
maus92
The OP
What is the purpose of "Field Communications" and "Command" talkgroups? How are they used in practice?
Also, does AACo use VRS's like DC and Montgomery Counties? If so, what units are they in?
pasadenamd
Pasadena, MD
Field Communications is supposed to be the direct communication from the on scene command to Fire Alarm. It is used on every single box assignment.
I have never heard units on the Command Talkgroup.
The VRS is a repeater system and it is on all the fire department units, I am told. They use it when they operate in a Hospital, the Jails, and sometimes when they are doing elevator rescues.
maus92
The OP
Following up, if the incident commander is on the field comm talkgroup, how does he/she monitor the tac channel? Does he/she have to monitor 2 radios? An assistant with another radio (tuned to the TAC channel?)
The VRS in Montgomery and DC have obvious extra antennae attached to the host vehicle - I haven't noticed the same stuff here in AACo. Interesting.
pasadenamd
Pasadena, MD
Here is a picture of BC 2's car that I took. It has two base radios in the back with a command post. The BC would also have another radio on their belt.
troymail
Silent Key
Anytime there are 3 or more units on a call, on of the units is required the take "command" and "field communications". Battalion Chiefs have the luxury of two radios so they can monitor both "fieldCom" (Delta for Echo or Foxtrot or Juliet for Kilo or Lima) and the fireground talkgroup. For lesser incidents, the units just have to make due. This is done for several reasons -- one - to ensure multiple units aren't calling in to fire alarm and second - because fire alarm generally only monitor the fieldcom talkgroups (particularly when they get really busy).
The VRS has been in place for years in AA County but almost never gets used. It's actually more complicated to use it than it really needs to be. In my opinion, it would be very easy for one or more units to get confused and end up totally out of radio communications when in fact it's designed to be just the opposite. It does get used for "regular' sites like Jessup prisons but that's usually done by crews assigned to the Jessup station -- it's one of those things that gets easier to use if you use it all the time... it's just not something people train on regularly so it's easy to mess it up.
In general, I believe one unit from each station has a VRS repeater including a 2nd antenna to support it - so in theory, there could always be one or more units on a incident that can serve as the "local site repeater".
