AbbVie/Abbott Laboratories - IL (DMR)
kbk777
Northbrook, IL
I'm relatively close to this system, but do not pick up anything. I have configured the system based on RR info. Does anyone have any knowledge or update?
Premises2972
What are you scanning on? Its possible the system is not updated and has changed, so you might need to do some exploration. Start with the the licensed frequencies, and see if you get any CC/LSN info, then you can start building the trunked system
kbk777
Northbrook, IL
I’m using RTL-SDR and SDS100. I scoured the 935 MHz band and it’s vast nothingness. I will research the licensed frequencies as suggested.
Premises2972
Check how powerful the repeaters are under the license, its possible they have a small coverage area for on site ops
belladog9651
IL
Look under the Lake Co trunk profile. There are 3 sites, with different frequencies. Keep in mind just because a license says 100watts output, doesn't mean the owner has the system set-up that way. It could only really be short range, or paperwork filed for future expansion. **Comparing the Radio Ref profile to the actual fcc data, it seems this system may have rebanded and has new frequencies. Please report back what you can find out. Thanks-
kbk777
Northbrook, IL
I found licensing information as shown here: ULS License - Other Indust/Land Transp. 896-901/935-940 MHz, Trunked License - WNQK681 - ABBOTT LABORATORIES
I put together a tentative band plan as listed in the FCC records. I assigned the new pseudo network ID of 681 (for WNQK681). I configured the three sites as follows: Site 1 (RT 41 & MLK Drive), Site 3 (1401 Sheridan Rd) and 5 (Abbott Park). All sites appear to be putting out 100w.
This did not work. Any ideas as to what might be missing?
Con+,681,1,1,935.2375,0.0,0
Con+,681,1,2,936.0625,0.0,0
Con+,681,1,2,936.3000,0.0,0
Con+,681,1,4,939.6625,0.0,0
Con+,681,1,5,939.9000,0.0,0
Con+,681,1,6,939.9125,0.0,0
Con+,681,1,7,939.9375,0.0,0
Con+,681,3,1,935.1375,0.0,0
Con+,681,3,2,936.0125,0.0,0
Con+,681,3,3,936.3625,0.0,0
Con+,681,3,4,939.9250,0.0,0
Con+,681,5,1,935.1875,0.0,0
Con+,681,5,2,935.8750,0.0,0
Con+,681,5,3,936.1875,0.0,0
Con+,681,5,4,936.3875,0.0,0
Con+,681,5,5,939.5125,0.0,0
Con+,681,5,6,939.8875,0.0,0
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Maybe they simply have nothing active on 900 mhz? Or maybe its so low power that you can't pick it up. It's probably all encrypted if it does exist. And unless the decimal network ID _is_ 681, and unless it _is_ actually a Con+ system, then all of the data you have put in the files will not help you to trunk track it. LCNs are likely not 1/2/3/4/5/6 on a Con+ either.
Your best bet is to manually step through every frequency on every site -- see if you can find ANY active freq. If it's active with a constant signal, then it's probably a control channel -- in which case you should tune to it with DSDPlus and see what the control channel output tells you.
mtindor
OH/WV DB Admin
Looks like someone found the new system info. I shall try it out.
I'm guessing at the bandplan. And since there is only a single frequency in the DB for each site, you aren't going to be able to trunktrack it with anything.
For DSDPlus, try this (assuming my bandplan calculation is correct, and it may not be):
DSDPlus
To differentiate this "S1" network from others you may encounter, per the DSDPlus documentation you can use a Network ID prefix to disambiguate this system.
The RRDB page is: Wood Communications (800 MHz LTR) Trunking System, Union City, Tennessee
The Network ID Prefix can range from 1-4096
It is recommended that the prefix be chosen from the first 3-4 numbers of the RRDB page (1293)
So in this example I have used 1293
DSDPlus.Networks
TIIInonStd,S1293:1,"AbbVie/Abbott Laboratories"
DSDPlus.Sites
TIIInonStd,S1293:1,1,"Abbott Park"
TIIInonStd,S1293:1,2,"Sheridan Rd"
TIIInonStd,S1293:1,3,"North Chicago"
DSDPlus.Frequencies
; AbbVie - Abbott Park
TIIInonStd,S1293:1,1,63,935.1875,0.0,0
TIIInonStd,S1293:1,1,283,935.875,0.0,0
TIIInonStd,S1293:1,1,383,936.1875,0.0,0
TIIInonStd,S1293:1,1,447,936.3875,0.0,0
TIIInonStd,S1293:1,1,1575,939.5125,0.0,0
TIIInonStd,S1293:1,1,1567,939.8875,0.0,0
; AbbVie - Sheridan Rd
TIIInonStd,S1293:1,2,47,935.1375,0.0,0
TIIInonStd,S1293:1,2,327,936.0125,0.0,0
TIIInonStd,S1293:1,2,439,936.3625,0.0,0
TIIInonStd,S1293:1,2,1579,939.925,0.0,0
; Abbvie - North Chicago
TIIInonStd,S1293:1,3,79,935.2375,0.0,0
TIIInonStd,S1293:1,3,343,936.0625,0.0,0
TIIInonStd,S1293:1,3,419,936.300,0.0,0
TIIInonStd,S1293:1,3,1495,939.6625,0.0,0
TIIInonStd,S1293:1,3,1571,939.900,0.0,0
TIIInonStd,S1293:1,3,1575,939.9125,0.0,0
TIIInonStd,S1293:1,3,1583,939.9375,0.0,0
Uniden Scanner
Code:
LCN    FREQ
39     935.2375
171    936.0625
209    936.300
747    939.6625
785    939.900
787    939.9125
791    939.9375
LCN    FREQ
23     935.1375
163    936.0125
219    936.3625
789    939.925
LCN    FREQ
31     935.1875
141    935.875
191    936.1875
223    936.3875
723    939.5125
783    939.8875
NOTE: This could be completely accurate, OR it could be completely INaccurate. I'm hoping the former.
Report your findings please !
Mike
kbk777
Northbrook, IL
@mtindor ... I logged the events below by tuning into each cc. I will do more research on this, but you are very close.
2024/06/25 15:33:58 Freq=936.300000 936.3 21.5 km 349 deg ABBOTT LABORATORIES RT 41 & Martin Luther King Drive/NORTH CHICAGO/ 7K60FXE 13K6F3E
2024/06/25 15:33:58 Freq=936.300000 Current network: S2
2024/06/25 15:33:58 Freq=936.300000 Current site: S2-1.4
2024/06/25 15:33:58 Freq=936.300000 Current network: S1
2024/06/25 15:33:58 Freq=936.300000 Current site: S1-3
2024/06/25 15:33:59 Freq=936.300000 DCC=0 RAS S1-3 neighbor: Site S1-1; CC=141
2024/06/25 15:33:59 Freq=936.300000 DCC=0 RAS S1-3 neighbor: Site S1-2; CC=789
2024/06/25 15:33:59 Freq=936.300000 DCC=0 RAS No data for current site found in DSDPlus.frequencies file
2024/06/25 15:34:08 Freq=936.300000 DCC=0 RAS Subscription Request; Tgt=80990 Src=TATTSI
2024/06/25 15:34:08 Freq=936.300000 DCC=0 RAS ACK: SUBSCRIPTION Tgt=80990 Src=TATTSI
2024/06/25 15:34:19 Freq=936.300000 DCC=0 RAS Group call; TG=118 RID=85038 Ch=172
2024/06/25 15:34:27 Freq=936.300000 DCC=0 RAS Group call; TG=118 RID=85029 Ch=172
2024/06/25 15:34:44 Freq=936.068750 DCC=0 RAS Group call; TG=118 RID=85029 Slot=2 2s
2024/06/25 15:35:23 Freq=935.512500 935.5125 219 km 177 deg Machine License Holding, LLC. 12141 KICKAPOO PARK RD/DANVILLE/VERMILION 12K8F1D
2024/06/25 15:35:35 Freq=939.512500 939.5125 20.3 km 345 deg ABBOTT LABORATORIES 100 Abbott Park Rd/Abbott Park/LAKE 7K60FXE
2024/06/25 15:35:57 Freq=939.512500 DCC=0 RAS Group call; TG=320 RID=85297 Slot=2 2s
2024/06/25 15:36:21 Freq=939.512500 DCC=0 RAS Group call; TG=320 RID=85294 Slot=2 2s
2024/06/25 15:37:00 Freq=939.925000 DCC=0 RAS 939.925 23.2 km 359 deg ABBOTT LABORATORIES 1401 Sheridan Road/North Chicago/LAKE 7K60FXE
2024/06/25 15:37:00 Freq=939.925000 Current network: S2
2024/06/25 15:37:00 Freq=939.925000 Current site: S2-1.3
2024/06/25 15:37:00 Freq=939.925000 Current network: S1
2024/06/25 15:37:00 Freq=939.925000 Current site: S1-2
2024/06/25 15:37:01 Freq=939.925000 DCC=0 RAS S1-2 neighbor: Site S1-1; CC=141
2024/06/25 15:37:01 Freq=939.925000 DCC=0 RAS S1-2 neighbor: Site S1-3; CC=209
2024/06/25 15:37:01 Freq=939.925000 DCC=0 RAS No data for current site found in DSDPlus.frequencies file
2024/06/25 15:37:06 Freq=939.925000 DCC=0 RAS Group call; TG=201 RID=80127 Ch=220
2024/06/25 15:37:29 Freq=939.925000 DCC=0 RAS Group call; TG=201 RID=80926 Ch=220
2024/06/25 15:37:32 Freq=936.300000 DCC=0 RAS 936.3 21.5 km 349 deg ABBOTT LABORATORIES RT 41 & Martin Luther King Drive/NORTH CHICAGO/ 7K60FXE 13K6F3E
2024/06/25 15:37:32 Freq=936.300000 Current network: S2
2024/06/25 15:37:32 Freq=936.300000 Current site: S2-1.4
2024/06/25 15:37:32 Freq=936.300000 Current network: S1
2024/06/25 15:37:32 Freq=936.300000 Current site: S1-3
2024/06/25 15:37:33 Freq=936.300000 DCC=0 RAS S1-3 neighbor: Site S1-2; CC=789
2024/06/25 15:37:33 Freq=936.300000 DCC=0 RAS No data for current site found in DSDPlus.frequencies file
2024/06/25 15:37:33 Freq=936.300000 DCC=0 RAS S1-3 neighbor: Site S1-1; CC=141
2024/06/25 15:37:38 Freq=936.300000 DCC=0 RAS Group call; TG=201 RID=80127 Ch=172
2024/06/25 15:37:40 Freq=936.300000 DCC=0 RAS Group call; TG=312 RID=85584 Ch=171
2024/06/25 15:37:43 Freq=936.300000 DCC=0 RAS Group call; TG=201 RID=80926 Ch=172
2024/06/25 15:37:54 Freq=936.300000 DCC=0 RAS Group call; TG=201 RID=80926 Ch=172
2024/06/25 15:38:44 Freq=939.512500 DCC=0 RAS 939.5125 20.3 km 345 deg ABBOTT LABORATORIES 100 Abbott Park Rd/Abbott Park/LAKE 7K60FXE
2024/06/25 15:39:23 Freq=939.925000 939.925 23.2 km 359 deg ABBOTT LABORATORIES 1401 Sheridan Road/North Chicago/LAKE 7K60FXE
2024/06/25 15:39:24 Freq=939.925000 Current network: S2
2024/06/25 15:39:24 Freq=939.925000 Current site: S2-1.3
2024/06/25 15:39:24 Freq=939.925000 Current network: S1
2024/06/25 15:39:24 Freq=939.925000 Current site: S1-2
2024/06/25 15:39:24 Freq=939.925000 DCC=0 RAS S1-2 neighbor: Site S1-3; CC=209
2024/06/25 15:39:24 Freq=939.925000 DCC=0 RAS No data for current site found in DSDPlus.frequencies file
2024/06/25 15:39:24 Freq=939.925000 DCC=0 RAS S1-2 neighbor: Site S1-1; CC=141
2024/06/25 15:39:26 Freq=939.925000 DCC=0 RAS ACK: REG/DEREG ACCEPT Tgt=85714 Src=REGI
mtindor
OH/WV DB Admin
Actually, I think I calculated everything correctly. What you would put in Uniden is definitely correct. And almost 100% certain the info for DSDPlus is fine as well.
You should try the DSDPlus.Networks / .Sites / .Frequencies stuff and see what happens.
kbk777
Northbrook, IL
I just realized that from your post with data, the LCNs in the Uniden Scanner section do not match up with your DSDPlus.Frequencies data. Or am I missing something? Also for side ID, should it not be S1 for size, and 1 (or 2 or 3) for site?
mtindor
OH/WV DB Admin
They aren't suppsoed to. Uniden scanners use LCNs. DSDPlus uses LSNs. I already told you why i set things up the way i did -- disambiguation. If you set up your DSDPlus file using S1, you are inevitably going to run into completely separte S1 systems down the road that have nothing to do with Abbvie and you will be confused. Everybody and there mother who sets up a TIII network likes to use S1 or L1..
It's not like if you put that stuff in your files your computer is going to get hacked. Paste the stuff in. If it works, great. If it doesn't, remove it.
kbk777
Northbrook, IL
I get what you're saying, I'm an IT professional so I have no issues with computer use :) I do understand the need for disambiguation, but I'm confused as to the formatting of it. Sites file has the below samples and I'm just trying to make sense of it for my own sanity. I want to have a solid basic understanding of DSD+ and then I can expand from there. That said, I will be physically closer to those sites later this week and will do my testing with your configuration. Thanks for your help!
; line format: protocol, networkID, siteNumber, "site name"
; for TIII, siteNumber format = area.site
; for TIIIStd and TIIInonStd, add TIII model code (T/S/L/H) before networkID
; for TIIIStd, siteNumber format = area.site
; for TIIInonStd, siteNumber format = site
mtindor
OH/WV DB Admin
I get what you're saying, I'm an IT professional I have no issues with computer use :) That said, I do understand the need for disambiguation, but I'm confused as to the formatting of it. Sites file has the below samples and I'm just trying to make sense of it for my own sanity. I want to have a solid basic understanding of DSD+ and then I can expand from there.
This is a Motorola Capacity Max (CAPMAX) system, thus a TierIII non-standard system.
pre-disambiguation:
TIIInonStd,S1,1,63,935.1875,0.0,0
post-disambiguation:
To disambiguate, you add a number from 1-4096 and then a colon :)) between the Network Model (S) and the Network ID (1) -- thus S1293:1
Per the DSDPlus notes.txt file, it is recommended to use the first 3-4 numbers of the RRDB page
That page is:
Code:
https://www.radioreference.com/db/sid/12934
Since you can't use 12934 (its larger than 4096), I chose 1293. You can choose whatever number you want. but with this disambiguation setup, you are pretty much not guaranteed to ever run into another TIII system that is S1293:1 lol.
Mike
mtindor
OH/WV DB Admin
pre-disambiguation:
That page is:
Code:
Mike
PROTOCOL, NETWORK ID, SITE NUMBER, LSN/CHID, OUTPUT FREQ, INPUT FREQ, SORT ORDER
Sort Order doesn't matter, but it needs to exist
Input Freq is useless, so everyone sets it to 0.0
Output Freq is the trunked repeater freq
LSN/CHID is a pair (like 171/172) but you only need to add one of them --I add the odd ones
Site Number -- the Site ID (this site is 1)
Network ID (combination of the Network Model and Network ID -- S1)
Protocol - self explanatory
kbk777
Northbrook, IL
I have made some progress with this, but I see something in the event log that I don't understand. When I load the Abbott Park site, It loads the site and network, but appears to block a change from S2 to S1293:2. It then lists it as an S2 network with site 1.2.
2024/07/01 15:54:39 Freq=300.000000 RAN=1 Loading TIIInonStd site S1293:1-1 [Abbott Park]
2024/07/01 15:54:39 Freq=300.000000 NAC=141 Current network: S1293:1 AbbVie/Abbott Laboratories
2024/07/01 15:54:39 Freq=300.000000 NAC=141 Current site: S1293:1-1 Abbott Park
2024/07/01 15:54:40 Freq=300.000000 NAC=141 Tuning to 935.187500; dwell time = 1.25 sec
2024/07/01 15:54:41 Freq=935.187500 NAC=141 Tuning to 935.875000; dwell time = 1.25 sec
2024/07/01 15:54:41 Freq=935.875000 Current network: S2
2024/07/01 15:54:41 Freq=935.875000 Current site: S2-1.2
2024/07/01 15:54:41 Freq=935.875000 DCC=0 RAS Blocking network ID change from S2 to S1293:2
2024/07/01 15:54:42 Freq=935.875000 DCC=0 RAS Found control channel
2024/07/01 15:54:42 Freq=935.875000 Current network: S2
2024/07/01 15:54:42 Freq=935.875000 Current site: S2-1.2
2024/07/01 15:54:42 Freq=935.875000 Current network: S1293:1 AbbVie/Abbott Laboratories
2024/07/01 15:54:42 Freq=935.875000 Current site: S1293:1-1 Abbott Park
2024/07/01 15:54:42 Freq=935.875000 DCC=0 RAS S1293:1-1 neighbor: Site S1293:1-3; CC=209 North Chicago
2024/07/01 15:54:42 Freq=935.875000 DCC=0 RAS S1293:1-1 neighbor: Site S1293:1-2; CC=789 Sheridan Rd
2024/07/01 15:55:21 Freq=935.875000 DCC=0 RAS Subscription Request; Tgt=80150 Src=TATTSI
2024/07/01 15:55:22 Freq=935.875000 DCC=0 RAS ACK: SUBSCRIPTION Tgt=80150 Src=TATTSI
2024/07/01 15:55:24 Freq=300.000000 DCC=0 RAS Loading TIIInonStd site S1293:1-1 [Abbott Park]
2024/07/01 15:55:24 Freq=300.000000 Current network: S1293:1 AbbVie/Abbott Laboratories
2024/07/01 15:55:24 Freq=300.000000 Current site: S1293:1-1 Abbott Park
2024/07/01 15:55:24 Freq=300.000000 Tuning to 935.187500; dwell time = 1.25 sec
2024/07/01 15:55:26 Freq=935.187500 Tuning to 935.875000; dwell time = 1.25 sec
2024/07/01 15:55:26 Freq=935.875000 DCC=0 RAS Found control channel
2024/07/01 15:55:26 Freq=935.875000 Current network: S1293:1 AbbVie/Abbott Laboratories
2024/07/01 15:55:26 Freq=935.875000 Current site: S1293:1-1 Abbott Park
2024/07/01 15:55:26 Freq=935.875000 Current network: S2
2024/07/01 15:55:26 Freq=935.875000 Current site: S2-1.2
2024/07/01 15:55:27 Freq=935.875000 Current network: S1293:1 AbbVie/Abbott Laboratories
2024/07/01 15:55:27 Freq=935.875000 Current site: S1293:1-1 Abbott Park
2024/07/01 15:55:27 Freq=935.875000 DCC=0 RAS S1293:1-1 neighbor: Site S1293:1-2; CC=789 Sheridan Rd
2024/07/01 15:55:27 Freq=935.875000 DCC=0 RAS S1293:1-1 neighbor: Site S1293:1-3; CC=209 North Chicago
mtindor
OH/WV DB Admin
My guess would be that either you have a poor signal for that site, or that there is interference affecting the copy of the control channel, or that you are picking up competing signals on the same frequency.
In my mind you don't have a solid 20db+ SNR signal without interference. It's having difficulty seeing the constant data that would indicate that it is a CAPMAX system (usually the manufactuer ID in the datastream). It needs to be able to see the signal, then get enough of the signal to see the telltale characteristics of a CAPMAX system, then switch to the CAPMAX networkID:SysID, and then make the transition to the disambiguated site NetworkID.
IF you have no other "S1" Network ID in your files, and if you are willing to not put another "S1" Network ID in your files even if you find one (as I said before, S1 CAPMAX network IDs are all over the place across the world),then you could strip the disambiguation from DSDPlus.Networks, .Sites, and .Frequencies just to make things less confusing for yourself. When I say strip I mean anywhere in files that you see S1239:1, replace with S1 .
But likely won't fix the issue because I think the issue is an issue of poor decoding. It seems to be having trouble hanging on to the control channel. Notice the "dwell time" stuff and the "found control channel" multiple times.
