About repaired APX radio
SamMori
I have got an srx2200 radio, but it has an label says “repaired”. I am worried about whether the repaired radio will have problems again. Can someone tell me when the radio will be sent back to the factory for repair, and if it is not repaired and passout , will it still be labeled for “repaired ?
Thanks!
MTS2000des
5B2_BEE00 Czar
This is normal for a properly repaired IS radio, the labeling has to indicate it was opened/repaired and properly resealed/pressure/leak tested. IS radios only hold their rating if the housing is intact and radio only serviced by an IS certified repair facility, with proper documentation of all servicing done, and the unit marked as "repaired" if the housing or chassis serviced/replaced.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
There is no reason to believe that a radio that has been repaired is going to fail again, unless that particular type of radio has a known common type of failure which may be expected to be seen again.
Random component failures are a thing. They happen.
SamMori
Thats mean if they just replace speaker or housing,radio still must be labeled "repaired"?
SamMori
If the radio doesn't repaired,they won't label that radio is repaired right?
MTS2000des
5B2_BEE00 Czar
If the housing is breached in any way, per the IS standards, yes, it has to be marked, documented in the service history, and a full pressure test done to ensure the radio is truly sealed.
IS ratings are all about documentation, which is why a used one should never be used in an IDLH setting unless it's provenance and service history can be verified.
SamMori
I asked my friend to verify this radio serial number to make sure it's repaired by the official, it is has recorded that it was repaired once at 2019, and have the “Last closed repair number”
ElroyJetson
Who's going to the trouble to forge the data plate to such a degree of accuracy as that?
NOBODY, that's who! Take it as proof of what it says it is, and get on with what remains of the rest of your life. :rolleyes:
Don't obsess over what's not worth obsessing over.
MTS2000des
5B2_BEE00 Czar
I would absolutely obsess over it if it's being used in IDLH applications. Ever been in a courtroom as a defendant in a LODD suit?
If it's being used for ham/GMRS/scanner, who cares.
If one's life depends on it, it ABSOLUTELY matters.
SamMori
Thank you for your answer and your patience.
SamMori
You're right,Thanks for your help and answer my question and your patience.
