Hi,
I just received my MFJ 1026.
Not knowing if it's "normal", I'm a little surprised by something : When the main antenna (long wire) is connected through the MFJ, before getting out to the receiver, I seem to loose 75% of the signal I receive. But au contraire, when the main antenna is connected directly to the receiver, the signal is way way stronger.
Is it the way it should be ? I did check everything was in order, connected everything properly, checked my wires, opened the MFJ to checker for the components.....everything seem to be ok.
Thanks,
Matt
Thanks,
Matt
