Can frequencies be entered manually such as 11 meters 27 mhz. ?
Would i need a different antenna to scan 11 meters if so what kind is
recommended,thanks.
Yes, you can manually enter 27 Mhz frequencies. Or, you could simply download (CB freqs/channels) from the RR Database using Sentinel.Can frequencies be entered manually such as 11 meters 27 mhz. ?
Would i need a different antenna to scan 11 meters if so what kind is recommended,thanks.
No, you can receive CB/11 Meters with the included antenna. However if you are seriously into CB, a roof mounted CB antenna should work better due to it's height.
seth21w... CB has been called 11 Meters since it's inception.
MENU --> Set Scan Selection --> Set Nationwide Systems then scroll to CB and hit E to enable/disable. Then SERV and scroll to OTHER and hit E to enable/disable.
